JAMES'S WEB SITE
Date:  2-26-2004
Number of Hours:  8.00
Brief Description:  Mount cab heater and fit Eng oil res.
Found that reservoir cap extended above firewall Modified bracket to lower the tank by 3/4". Using level determined min allowable oil level in reservoir and painted a red line level with the motor mount to indicate min allowable oil level . Installed Manifold and muffler and tryed to determine if conflicts exist. Some queston on the 180 bend. Will review after all springs and hangers are in place. Installed the Manifold and torqued all bolts to 31 ft #'s
