Today, I spent quite a bit of time riveting the center floor in place back behind the aft seat. I left the rest loose so It will be easier to adjust the rudder cables and safety the turnbuckles. Then I worked to install the seat belt brackets and then the seat belts. I also installed the aft bench seat and the two forward buckets. It doesn't seem like it should have taken that long, but it did.
