Today, I fitted the latching bar to the lower frame of the passenger seat. I also added split rings to each lock to attach them to the latching bar (on both seats) Then, I removed all the seats from the aircraft and then worked to rivet all four seat tracks to the cabin floor. I also spent a bit of time fitting the terminals on the prop governor control. Missing one small nut -- guess if I clean up the shop I'll find it.
