Today, I began work on the bracing that supports the instrument panel. The plans are weak in this area, they state you need to gently bend the 5/8 x 5/8 inch tubing. Not possible as it has to change direction quite a bit. In the end, I bent the two pieces that come from the end of the panel by dirlling a hole, then using the band saw I cut a notch. With one side remaining, they were easy to bend. Then you just add a gusset to the top.
