Jerrys Web Site
Date: 12-27-2014
Number of Hours: 7.00
Brief Description: Rear Cabin
Today, I continued to finish off a few little jobs. First, I removed, deburred, cleaned and primed the webs under the cargo floor area, and then riveted in place. I also finished the angles on the cargo floor at Station B. Then, I re-riveted the nutplates on the right upper inner door post with stainless rivets. I then riveted the inner door posts in place, leaving enough removed to slip the panel in/out, as well as the lower forward corners. Finally, I deburred, cleaned, and riveted the right upper door corners in place.
Station A Floor Crossmembers
Inner Door Post Complete
Right side upper corners complete
