Jerrys Web Site
Date: 10-2-2014
Number of Hours: 7.00
Brief Description: Inner Floor
Everything simply takes a long time. Today, I spent most of the day working on two brackets. First, I cleaned up/deburred the SA-201 brackets I cut out for the seat belt anchors. Then, I primed the two outer bracketrs, installed the F5000-4 nutplates, and then riveted them in place. I had to match drill the holes for the steps from the back, as well as a rivet on the inner flange of the Station 4 carry through. To do that, I had to remove the rivet, as well as the rivet on the false carrythrough and then drill from behind. Finally, I drilled the holes in the floor for the seat belt anchors.
At the end of the day, I pulled all the parts for the seats/seat rails.
Step Complete
Inner Seat Belt Doublers
Outer Seat Belt Doublers and Step
