Today, my wife helped to finish the last upper long wrap on the left side. I then removed the forward wraps, upper and lower, trimmed, removed the plastic from the rivet lines, and then reinstalled. I installed the two upper half wraps between A and B, and then worked on the left upper corner. It's completely match drilled and has a good fit. I used a rubber mallet to stretch the edge a bit for a good fit on the aft portion of the wrap. Next, I'll work on the upper right corner and then complete the shear webs beneath the cargo compartment.
