Jerrys Web Site
Date:  5-30-2014
Number of Hours:  6.00
Brief Description:  Tail Cone Corner Wraps
Today, I finished shoring up the fuselage with four 2x4's on edge. Then, I cut plywood to lay across the bulkheads. My friend Don came over to help, he applied pressure on the outside while I drilled from the inside. He also put cleco's in place. Next session, the bottom corner wraps.
Match Drilling from Inside
Helper Don
Helper Don
Corner Wraps on Top
Corner Wraps on Top
