Today, I worked to make the angle brackets that held the R-BULK assemblies to the bottom channel of the root rib. I also took the time to straighten a couple of things up. In addition, I cut and fitted two angles that fit between station 5 and 8 at the top of the outer post skin. Finally, I set the upper skin in place, clamped and drilled it in place through the two outer brackets on the front carry through. I then back drilled through the positioning holes on the R-BULK assemblies to align the skin and hold it in place.
