Today, I worked to fit the left landing gear drag link modification. It took careful filing of the u-shaped piece that matched up to the center bolt in Station 3. I completed the fit, drilled the holes in the fuselage sill to 3/16 (one size larger than the plans) then cleaned, primed, and set it aside. I will fit it later as I'm waiting on parts to install the front float attach fittings. They use the same bolt that attaches the drag link mod to Station 3.
