Today, I finished riveting the stringers and then turned my attention to the bottom skin. Removed the plastic on the inside and used the soldering iron on the outside to carve a path for the rivets. Then, I aligned per plans, and then match drilled the holes to #40, then to #30 except for outer perimeter. Tomorrow, I'll deburr, prime and rivet.
