Jerrys Web Site
Date: 12-6-2013
Number of Hours: 6.50
Brief Description: Left Aileron
Today, I installed the aileron on the wing and drilled the center hinge in place per the plans. Then, I worked to fabricate and install the cover on the center hinge section. In the afternoon, I worked on the aileron spade skin/counterweight install. The skin is straightforward, but the counterweight poses a few challenges. On the first aileron, I learned to install the counterweight before riveting the bottom of the skin per the plans. The rivet tails got in the way and I had to drill them out. In addition to the 3/16 inch rivets in the bottom, I also drilled the first two #30 holes in the spade skin/ribs into the counterweight as well. So, it is held in securely on all corners plus the larger 3/16 inch rivets on the bottom. In addition, I covered the counterweight with proseal before installing the skin for the last time. A bit of riveting left, then clean up the rivet heads on the aileron, then install the inspection covers and it will be complete.
Working on Center Hinge Cover
Spade Skin Installation
Counterweight
