Jerrys Web Site
Date: 3-16-2012
Number of Hours: 7.50
Brief Description: Skin Installation
Today, I pre-drilled the first hole on the bottom of the rib per the plans, then match drilled the left aileron skin, then enlarged the holes. This time, every single nose rib hole was drilled exactly on centerline! Experience is kicking in. Then, I removed the plastic, and finished the afternoon deburring, scuffing and cleaning the skin. Next session, I'll debur the rib framework, then I need to prime the left flap, right and left ailerons prior to final riveting.
Match Drilling the Left Aileron
Removing Plastic from Left Aileron
Grand Dog "Bodie" Visits
