Today, I completed deburring the inspection cover between stations 6 and 7. I also fitted and drilled the stringer covers for the upper tank skin. Then, I scotch brite'd and cleaned the areas I planned to proseal. After lunch, I mixed up proseal and went for it. I cleco'd the lower tank skin 100% and then after supper, went out and riveted all but the inner ribs. I'll finish them in the morning.
Old golf shafts will keep the skin off until I work each rib
