Brief Description: Left Wing Final Details prior to Closing Up
Today I worked to finalize everything prior to prosealing the lower wing skin in place. I primed the inside leading edge, as well as the inside lower wing skin outboard of the fuel tanks. I installed the Tru Trak Roll Servo -- still need to safety wire it as my wire was at the hangar. I also did a bit more clean up, scotch brite and deburring prior to priming. I also changed my ground post for the position light by adding aluminum washers next to the spar (per Tony Bingelis). I probably have two to three more hours of work prior to prosealing the wing skin in place.
