Brief Description: Left Wing Autopilot Servo and Pitot Static
Today, I completed the pitot system. I decided to put the static ports on the fuselage and only use the pitot feature of the tube. I used a Safe T Air system from Avery Tools.
I also completed the roll servo hardware installation. I had to remake the stiffener as I encountered a problem with the location between two j-channels. I also made a plate to fill the gap where the bracket rested on a channel stringer.
