Jerrys Web Site
Date: 6-29-2013
Number of Hours: 2.00
Brief Description: Final Disassembly
Wow -- its been a while. I've been driving to the airport each day to fly the Cygnet -- trying to get the 40 hours flown off to go to Oshkosh. In addition, I've been working on it tweaking this and that, getting the cooling correct, etc. Everything is coming together nicely.
So, today, I went out and cleaned up the shop, then match drilled a few final holes, deburred some access panel holes, and then removed the wing leading edge. I will only have to make three rib flange patches, as I drilled almost all of these dead center. Lots of deburring now, and then priming the large wing skins.
