Well, after I realized I had a fuel leak on Saturday, I came down with Strep Throat -- ugh. What a week. Today, I was able to muster up enough strength to finish riveting the lower part of the leading edge wing extension. I then had a neighbor help to turn the wing back over -- tomorrow, I'll begin work to fix the leak. My A2 Proseal arrived today from Wicks. I plan to introduce some warm air to make sure all the water is out of the joint, then introduce a vacuum and try to pull some of the more liquid type proseal through the joint. I'll then go inside and fillet the flange between the spar and the tank skin.
