Jerrys Web Site
Date: 12-16-2011
Number of Hours: 5.00
Manual Reference: 6.7
Brief Description: Wing and Tank Skin Installation
Today, I finished match drilling the bottom tank/wing skin, and then attached the leading edge. I drilled the leading edge to the ribs. This is difficult, I missed a couple because even though you have the line on the center of the rib showing under the hole, when you begin to drill it drives the rib off to one side. I've tried center punching, but it doesn't always hold the drill. After completing this, I removed the leading edge, cleaned it up, and dashed outside in the cold to give it a coat of primer. Then, I enlisted the help of a neighbor to turn the wing over. Next, I will make twelve small patches to close up the stringer holes in the last rib of the fuel tank.
Bottom Skin and Leading Edge in Place
