Jerrys Web Site
Date: 11-22-2011
Number of Hours: 2.50
Brief Description: Flight Controls
This evening, I pulled all the parts for the control assembly in the wing. First step was to drill 8 holes in a round ring. I measured them out (7/8") on a piece of paper, taped it to the ring, center punched then drilled on the drill press. On an earlier project, I welded two pieces of angle iron together -- worked well to hold the ring. Then, I fitted a plug into the end of the tube, installed a 5000-4 nut plate with flush rivets, then bolted the control arm on and drilled out those holes to #11. The final step was to match drill the ring to the tube. Today, I'll disaaemble, debur, and begin to work on the mounting brackets.
Parts Identified
Paper strip to divide into 8 sections
Cleco'd Assembly
