Today, I riveted the 8 outboard nose ribs to the main spar (area covered by the spar extension). I had to ream each hole out to get them to accept the rivets, due to the # of laminates/thickness. I dipped each 3/16 rivet in primer and installed.
In addition, I deburred, scuffed and primed the outboard leading edge. I also fitted the two angle stiffeners Charlie Eubanks helped me to make. I deburred, scuffed and primed them as well. I'll likely hold off to install them, until after the wing skins are ready -- so can remove and deburr them one more time.
