Today, I wired the power to the four lighting switches. Then, I ran the wire forward from the tail light and also the strobe light. I connected the strobe light to the switch and also grounded it to the airframe. A quick test shows it works. We'll see about static when I test the radios. The strobe light is a replacement bulb for an AeroFlash from PSA Enterprises in Lakeland FL. It allows you to remove the power supply from the light.
