Today, I installed the Hall Effect Sensor to measure amperage. I mounted the circuit board on a piece of angle. The #6 wire will come in the pass thru at the top of the picture and go down through the sensor, then over the right to the buss bar. I'll probably use an Adel clamp above and below the sensor to isolate the wire from any vibration.
