Today, I mounted the VSI and the Airspeed Indicator on the Panel. For the VSI, I had to mark and cut out a space for the lip in the lower left corner. I made a template then drilled little holes, then used a dremel sanding drum to finish the job. It did chip some of my paint on the edge, I should be able to cover it with black marker.
