Jerrys Web Site
Date:  6-29-2017
Number of Hours:  5.00
Brief Description:  Hoses
Today, I made up the primary hose from the fuel pump to the fuel pressure cube. I also made the hose that fed the fuel pump. I've learned the PFTE isn't as flexible as the poly tubing I used to size everything, so had to make allowances for that. I also installed the prop governor bracket. I got it back from the Powder Coat guy.
