I flew the Cygnet this morning, so got a late start. First, I continued to work on the prop governor bracket, lightening it up a bit with some scallop cuts. I drilled small holes and then broke the piece off, then smoothed it up on the grinder. Next, I secured the prop governor cable on the oil sump bolts with small adel clamps. Finally, I worked to add adel clamps on the engine mounts to support a variety of wires. Amazing how hard that is.
