Today, I spent a lot of time working on the cowling and baffles. I had to remove some more material in the cowling inlets to get it to fit over the baffles. I also worked to locate the inlet for the Vans Air Box Filter and cut the initial hole. It now needs to be enlarged upward and then a scoop formed for the outer portion of the cowling. I was very happy with the spinner to cowling clearance.
