Today I worked to complete the final riveting. Unfortunately, I didn't complete it as I forgot to drill the 1/2 inch hole to install the top rudder hinge bolt in the forward bottom rib. It took me quite some time to gain access and then figure out how to do it. The dremel came through again! Consequently, I only completed a bit of the leading edge on one side of the rudder.
