Today, I installed the two fuel sight guages. All that is left is to order the correct size grommets and split and bond in place. I also powered up the aircraft and did the initial setup on the EMS with the correct ranges etc. Finally, I added 15 gal of fuel to each tank, 5 gallons at a time. That was enough in the ground attitude to completely fill the bottom of the tank. Unfortunately, I have a leak on the right tank near the aft wing root, where there is an access panel. I'll look at it some more tomorrow and make a decision on what to do. If its only one rivet, I may try and simply replace it. if it appears to be more, I may need to go in through the top of the tank with a patch. Tomorrow we're going to run the engine for the first time.
