Again, a pretty miserable day. It got up to 19 degrees, but the hangar floor is so cold soaked it was really miserable. I continued to work inside the cabin, completing the access panels, but first checking for leaks etc. I then did the ground test on the Digitrak. It didn't work at first, but checked and I had blown a fuse. Probably during my first ground runs before I made the connection at the wing root -- most likely power and ground shorted out. Nice to know the fuse architecture works! I replaced the fuse and completed the checks. All was ok, except the direction. Left was right and right was left. Tomorrow, I'll reverse two pins and it should fix the problem. My servo is mounted upside down in the left wing and that's probably why. Finally, I worked to add the left wing root fairings to make sure they fit after I added the rubber molding.
Today, Cinder was so cold he jumped in the back seat of the truck and let me cover him up with a moving blanket. He didn't move for two hours at which point he came back in the hangar and jumped up in the back seat of the cabin.
I just noticed -- it has been exactly 7 years since I began unpacking my crate in the shop.
