Today, I spent a little time working on the primer, and realized I needed to order more fittings. Then, I began to work on fabricating my hoses. I selected a small one from the fuel pressure cube to the carb to start with. After struggling, I went back in and watched a couple more videos and realized methods vary by manufacture. Actually, the PFTE hose I ordered from Summit Racing was fairly simple. That said, the PFTE is not as flexible as the poly I was using for sizing, so will have to move the fuel cube a bit. Tomorrow should be a good day.
