Today, I cut holes and installed the cabin heat box and five spherical metal grommets. I used fuel lube (Boelube) for a cutting fluid and it worked great. I simply put a little on with an acid brush. I deburred them with a grinding wheel in my dremel. The cabin heat was a two inch hole and the grommets were 1 and 1/8 inch holes.
