Today, I made three brackets for the map and dome lights. They are simple angled brackets that hold a small egg shaped LED light at the proper direction. I placed a green LED above and outboard of the pilot and copilot. I also placed a white LED above the door aft of the cargo compartment that shines across the entire cargo compartment. In addition, I added a ground wire for two wires that were labeled as chassis ground, one from the KLX-135A and one from the PM1000II. Finally, I completed all the antenna connections at the radio end, and added a splitter for the tail mounted VOR/VHF antenna to split out Glide Slope and VOR/Localizer.
