Today, I completed the swap out to gold plated connectors for the King Avionics. I then reinstalled the trays, and put the radios in. Next, I began working on the primary electrical connections. For the most part, I'm soldering AMP connectors on the big wires, and crimping on the smaller wires. I also installed the side panel that houses the buses, basically fuse blocks from B and C. I should have made a list of each wire when I installed it on the buss. I need to go back and look at the labels and write each one down to make sure I get the correct size fuse.
