Jerrys Web Site
Date:  6-5-2015
Number of Hours:  1.00
Brief Description:  Fuselage Pass through
I located a bulkhead fitting for the 1/4 NylaFlow tubing on the brake lines on line. I had called MATCO to ask, and George recommended I look online, that there were several possibilities. I drilled a 3/8 inch hole and installed them. I still need to look for a 3/8 brass lock washer to make sure they don't back off.
Inside
Inside
Outside
Outside
