Today, I first worked to correct a geometry issue on one of my brake pedals. I moved the master cylinder forward one set of rivet holes, and simply plugged the old hole with rivets. I had one of them too close and it wasn't aligned with the others.
Next, I worked some more on my rudder cut outs, cleaning them up, sanding and smoothing the edges. I then nicopressed the bushing on the #2 rudder cable end.
Finally, I drew up a sketch and made a rudder cable fairing. I made it wide enough to put a RG-1 cable guide on the outside, but hidden by the fairing. I may reconsider putting the cable guide on the forward inside of the slot and making a smaller fairing.
