Jerrys Web Site
Date:  12-16-2014
Number of Hours:  5.00
Brief Description:  Cabin Fuel Lines
Lesson Learned -- put fuel lines in while building fuselage cage, not after skins are installed. It was very difficult to work in tight spaces, especially tightening fittings. I had no trouble flaring my tubing, I have a Parker Hannifan Flaring Tool from Aircraft Tool Supply that works really well. I used oil on every flare, and then assembled the fittings with Fuel Lube from ACS. I still need to make some means to hold the fuel valves in place. Basically, I have a 90 degree fitting that a tube will slip on from the wing tank. I used the Murphy valve, but replaced the Murphy fittings with Aluminum AN Fuel fittings. I ran the 3/8 inch OD tubing at a 45 degree angle through the Root Rib and Station 5 Bulkhead, using a piece of 1/2 PEX tubing to protect the tubing where it passed through the bulkheads. Unfortunately, I had to add a coupling at the top of the bulkhead, where the line transitions downward. I kept it near the top, see Image 3, and will add an access plate to look at it occasionally. I removed the upper rivets in the #6 bulkhead skin from the outside to allow me to move it slightly in order to tighten the fittings. I then ran the lines through the floor and teed them on the left side of the aircraft, and intend to add a gascolator just in front of the tee assembly, then transition it to the firewall. I also added an ADEL clamp halfway down the bulkhead, to keep the line from flopping free in the bulkhead assembly. I simply used an AN-4 bolt with an elastic stop nut to hold the clamp in place. Again, tight quarters.
Fuel Selector Valve
Fuel Selector Valve
Tee in Cabin Floor
Tee in Cabin Floor
Coupling at Top of Bulkhead
