Today, I spent some time installing the correct size bolts in the pedal assemblies where they bolt to the floor. Then, I drilled to #30 the two ribs for the mixing unit where they attach to the roof. I made a new plate out of .063 as I made a temporary one earlier while waiting on the thicker material to arrive. I also drilled them for the #11 holes for the actual mixing unit itself. Then, I removed them and cleaned, deburred, prep'd and primed. I also added the nutplates to the bottom of the ribs for actual mixing unit.
