Jerrys Web Site
Date: 6-14-2014
Number of Hours: 6.00
Brief Description: Cargo Door
Today, I removed the lower left forward corner wrap, final trimmed, deburred, prep'd and primed. I also did the same with the lower channel, the corners and the brackets. While it was off, I deburred, prep'd and touched up the primer on the outside and next inside shear webs and associated angles. I was able to rivet the outer shear web, and prepared to rivet the next one over, but then realized I was out of the correct size rivets. Because of the double angles, the normal 1412 rivets are too short. So, back to ACS for more rivets.
