Jerrys Web Site
Date:  6-3-2014
Number of Hours:  8.00
Brief Description:  Mating the Tailcone
Today, I completed the right side forward corner wraps. I trimmed the short one, and then fitted and trimmed the forward wrap. Next, I began work on the shear webs on the cargo floor area. These will be difficult. The top two angles are easy, match drill one, remove and then match drill the other. Install and then final drill to #30. The lower ones are already fixed, but not drilled. I used an angle drill and bent one angle out of the way, then moved it back into place. That allowed me to drill all the holes except the two forward ones. I'll still need to attach it to the floor, but not until the others are complete. Hopefully, the learning curve will kick in on this. It took all afternoon to do one shear web.
Inside Shear Web in Cargo Bay
