Today, I finished shoring up the fuselage with four 2x4's on edge. Then, I cut plywood to lay across the bulkheads. My friend Don came over to help, he applied pressure on the outside while I drilled from the inside. He also put cleco's in place. Next session, the bottom corner wraps.
