Finished fitting the nose ribs and drilled all the holes to size. Fit the strip that goes in between the nose rib and skin. This will connect the nose to the fuel tank. I dont think there is any easy way to fit it. I spent a lot of time shaping it and tapping it into place. I placed the nose rib on the wing and clecoed it all together. Too bad it all has to come apart again.
