JEFF'S WEB SITE
Date:  3-7-2005
Number of Hours:  3.75
Brief Description:  Finishing the HS
I riveted the rear spar to the skins. I riveted the inboard and outboard ribs the the spar. I used blind rivets on the 6 parts that couldnt be bucked. I assembled the hinge bracket bearing and installed. My first mistake of the project happened. I set the torque wrench wrong and stripped oneof the bolts out. Ill have to order another nut and bolt.
