I worked on the trim tab the whole time. I prepared all of the parts, made the foam blockes and wedges for stiffening the skin. I mounted the spar to the bottom of the skin. I mounted the control horns. I bent the edges of the trim tab. Mixed up pro-seal and applied to the foam wedges. I inserted the wedges and used the v-clamps to hold them in place. I will finish up the trim tab next Monday.
