JEFF'S WEB SITE
Date:  6-27-2005
Number of Hours:  5.50
Brief Description:  Trim tab
I worked on the trim tab the whole time. I prepared all of the parts, made the foam blocks and wedges for stiffening the skin. I mounted the spar to the bottom of the skin. I mounted the control horns. I ben the edges, mixed up the pro seal and applied to the foam wedges. I inserted the wedges and used the v clamps to hold them in place. I will finish up the trim tab next monday.
