Brief Description: Right ER Tank Fuel Flange and Outboard Rib
The right fuel tank went a lot faster than left side. I kind of expected this because working with proseal is getting easier. I finished riveting the outboard rib on the right side. This time I primed everything before I prosealed in place. Either way I will be priming any exposed aluminum because rear baffle and aft end of tank skin need to me protected. Priming over the proseal is no bog deal but not the other way around.
