John's RV10 Project Build
RV10
Installing OB Fuel Level Sender
Installing the OB fuel level sender for the Sky Designs ER tanks. Used modest amounts of proseal to make sure there will be no leaks.
I am using the stock Vans Stewart Warner floats.
The float arm is bent differently than inboard sender. This OB sender will have range of motion from half to full.
IF YOU WANT TO SEE A VIDEO OF MY ER TANK SETUP AND TUTOURIAL PLEASE SUBSCRIBE TO MY YOUTUBE CHANNEL : @JERSEYPILOT83
RV10 Home
503
Aileron
Aileron Bellcrack
Bottom Wing Skins
ER fuel tanks
25
84
Flaps
Fuel Drain Flange
Fuel Level Sender
Fuel Tank Attach
Fuel Tank Fittings
Fuel Tank Leak Test
Fuel Tank Skin
Fuel Tank Vent
Fuel Vent Lines
Fuselage Bulkheads
IB Fuel Level Sender
LE Attatch to Spar
Locking Fuel Caps
OB Fuel Tank Rib
Stall Warning System
Vertical Stabilizer
wing conduit
Wing LE Spar
Wing leading edge sp
Wing OB Leading Edge
Wing Outboard Leadin
Wing Spar
Wing Spar ER tank
Wing Spar ER tank Al
Wing Spar Nutplates
Wing Top Skin
Wing Wiring
