I found in a CP that the recommended way to flip this airplane over is to Bolt a 1" thick Pine board to the spar and lay the airplane on it's nose while it rolls over, if you will. I felt a little nervous about the pine board because pine is so soft. I opted to add a 90 degree angle with screws and glue to make the board a bazillion times more rigid. That should do it :)
