Building Integrity
Date:  6-6-2018
Number of Hours:  1.00
Manual Reference:  Section 2
Brief Description:  Balancer coating take 2.
The balancer I've had was painted and the paint failed after the first run do to the intense heat. I took the balancer to a local powder coater and they wanted a rediculous $75 for it. Heck no! Instead I went with a high temp engine paint by VHT and will be seeing if this will work out better than the paints I've used so far. Here's to luck on my side!
Paint removed using Xylene.
VHT High temp engine paint
