Building Integrity
Date:  5-8-2018
Number of Hours:  3.00
Manual Reference:  Section 2
Brief Description:  The engine install is complete!
It seriously took me 3 hours to finalize just a couple tasks. Sheesh. Well, the cylinder plenums needed grommets glued in place to protect the plug wires. And then the oil cooler plenums were installed along with weather stripping to seal off the airflow. However, the stripping changed the angle of the plenums, requiring me to modify the installation a bit, in order to get a good fit to the cowling exit. Ugh. Annoying...BUT DONE.
So now, the only thing left to do is wait for the exhaust pipes to come back from Jet-Hot with a purdy polished Ceramic coating. Until then, there is still work to be done. The Fuselage will be trailered to the airport on Wednesday, but tomorrow I will be focusing on making all new rudder cables and tidying up any loose ends. It may also be another day of moving things to the new hangar and setting up shop for Wednesdays big arrival. :) I still need to balance the prop, Finish the cowls, wheel pants and canopy so there's no time to be wasting here :)
All together
All together
Cooler plenums are in
Ready to rumble
Ready to rumble
